Re: ST R μικροπροβληματάκια ¶
Από: Greg στις 07/07/2010 6:10 μμ.
Well what do ya know?! It WAS the tank hinge.
I simply unbolted the long bolt holding the hinge, pulled out the spacer with a pair of pliers and applied some grease to the bushings, and the spacer. You have to take off the 2 bolts on the front of the tank to give yourself some leverage to be able to take the hinge apart, but other than that it was an easy 15-20 minute affair.
I no longer have a little birdy chirpin' in my ears!!
εχει δοκιμασει κανεις τη συγκεκριμενη λύση και εχει δουλεψει;
