RSVSR Arc Raiders: Water Troubles Quest Guide ¶
Από: 1fuhd στις 10/01/2026 10:12 πμ.
The Water Troubles quest in Arc Raiders is one of the simpler story missions for new raiders, sending players to investigate contaminated water in the Dam Battlegrounds map. Assigned by Speranza at base, it guides you into Red Lakes to collect a sample from a flooded access tunnel, offering early hints about the settlement's failing infrastructure amid ARC machine threats. Completing it quickly gives reputation gains and opens follow-up quests like Source of the Contamination, making it a key early step without heavy combat or risky extractions ARC Raiders Coins.
Start by loading into Dam Battlegrounds—often called the Dam map for its massive central structure—and head to the southeast near the Control Tower POI, where Red Lakes stretch below a balcony overlook. If you're just questing, drop with a free kit; survival isn't critical. Mobility tools like ziplines or grapples help reach lower levels quickly, avoiding wandering Shredders in the basin. The balcony acts as a clear landmark: find the dam walls and descend via stairs, slides, or a high zipline into Red Lakes' lowest point.
Your first objective update triggers when entering the Flood Access Tunnel beneath the balcony. Look for a large dark opening at water level, partially submerged in murky pools. Two entrances exist: a lower one through the lakebed pipe or a higher path via zipline drop from nearby rooftops. Crouch or prone to slip past idle ARCs. The dim tunnel hides interactables, so use your flashlight or quest markers to navigate 50–70 meters to a shallow water chamber.
Collect the water sample at the intake pipe for the District's Water Supply, a grimy tube sticking from the tunnel's wall. No swimming or parkour is required—just wade into the ankle-deep puddle and interact with the yellow prompt. The collection completes instantly and updates your log without needing extraction; many players then wipe to respawn at base, saving time. Environmental hazards are minor, and the area remains light on enemies compared to busier spots like the dam itself.
Timing can improve efficiency. Try low-pop Expeditions or Trials to avoid ambushes, as Red Lakes draws looters near bunkers and caches. In duos or trios, split roles: one scouts the tunnel while others cover flanks or gather side loot like medkits. You can also chain objectives, grabbing the sample after nearby tasks like Our Presence Up There for bonus reputation. Recent 2026 patches improved marker visibility, helping newcomers avoid getting lost.
Common issues are easy to fix. Stuck on the balcony? Drop prone or find the nearby zipline. No interact prompt? Make sure you're in the southwest puddle, not a false pool elsewhere. Solo clears from spawn typically take 2–3 minutes, while groups can finish under 90 seconds using pings rsvsr ARC Raiders Items. If ARCs swarm, kite them into the pipe's chokepoint and use SMGs or grenades for easy stagger kills. Returning to Speranza automatically turns in the sample, granting honey tokens or base upgrades tied to water purification.
Water Troubles shows how Arc Raiders mixes exploration with risk management, turning a grim sewer slog into a reputation boost for new raiders. Master the Red Lakes descent, tunnel push, and quick sample grab to breeze through it on fresh accounts or each season, freeing time for Trials runs and upcoming 2026 events.
