MMOexp:POE 2 chain explode stacker Martial Artist build ¶
Από: Florencehg στις 10/06/2026 8:50 πμ.
What if every enemy you killed didn't just die, but exploded into the next kill, and then the next? Can a Martial Artist setup in POE2 Currency 0.5 actually turn fast combat into a cascading chain reaction of destruction? The Chain Explode Stacker Martial Artist build is designed around exactly that idea. It focuses on rapid melee engagement, explosive on-kill effects, and stacking mechanics that amplify damage the longer you stay in combat. Instead of single-target bursts or slow scaling, this build transforms mapping into a nonstop chain explosion loop. But how does it actually work, and what makes it so effective for both speed farming and high-density encounters? Let's break it down.
Core Concept-Chain Explosions and Momentum Stacking
The foundation of this build is simple: kills trigger explosions, and explosions create more kills. In Path of Exile 2 0.5, the Martial Artist class can leverage fast-hit melee skills to consistently trigger on-kill effects that scale with enemy density.
The "stacker" aspect comes from building bonuses that increase damage after consecutive kills. This means the longer your kill chain continues, the stronger your explosions become. The result is a snowball effect where clearing speed accelerates exponentially rather than linearly.
Martial Artist Synergy-Fast Hits, Fast Chains
The Martial Artist ascendancy is ideal for this setup because it naturally supports:
Rapid attack speed scaling
Combo-based damage amplification
Mobility-focused melee engagement
Consistent hit frequency for proc effects
This allows the build to maintain constant pressure, ensuring enemies are always dying in clusters rather than individually. Once your chain begins, stopping is not an option-you are rewarded for continuous movement and aggression.
Skill Setup-Building the Explosion Engine
The skill setup revolves around combining fast melee skills with explosion-triggering mechanics.
Core components include:
A primary fast melee skill for constant hit generation
On-kill explosion effects or supports that trigger chain damage
A mobility skill to reposition between dense packs
Optional buff skill for stacking damage multipliers
Support gems prioritize attack speed, area of effect, and on-kill scaling, ensuring each kill contributes to the next explosion wave. The goal is to turn every engagement into a domino effect.
Gear and Scaling-Stacking Damage Over Time
Gear is critical for sustaining explosion chains and increasing their impact.
Key priorities include:
Increased attack speed for faster kill chains
Area of effect scaling to spread explosions further
Damage per kill or stacking bonuses
Defensive layers like evasion or energy shield for melee uptime
Advanced setups may also convert damage types to improve consistency against tougher enemies while maintaining chain reliability in high-density maps.
Mapping and Combat Flow-The Chain Reaction Playstyle
This build excels in mapping scenarios where enemy density is high. Instead of manually clearing packs, you initiate a chain reaction that spreads across the entire screen.
Combat flow looks like this:
Engage first pack with melee hits
Trigger first explosion
Chain spreads into nearby enemies
Stack bonuses increase explosion damage
Entire screen clears automatically
Bossing is slightly different, focusing more on stacking buffs and using melee damage directly, since chain explosions are less frequent in single-target fights.
Conclusion-Who Should Play This Build?
The Chain Explode Stacker Martial Artist build in POE 2 Currency Orbs 0.5 is ideal for players who enjoy fast-paced, high-impact mapping and visually explosive gameplay. It suits speed farmers who want maximum efficiency, as well as experienced players who enjoy optimizing chain reactions and stacking mechanics. However, it requires active positioning and aggressive playstyle to maintain momentum.
Helpful Tips
Always fight in dense packs to maintain chain value
Avoid overkilling single targets outside clusters
Prioritize movement speed for faster chaining
Build defenses to stay alive during aggressive melee play
Focus on scaling area damage for wider explosion coverage
Core Benefits by Player Type
Speed Farmers: Extremely fast map clearing through chain reactions
Advanced Players: High optimization potential with stacking mechanics
Melee Enthusiasts: Active, aggressive, high-impact gameplay loop
Endgame Players: Strong scaling in dense encounter environments
Helpful Tips
