MMOexp:ARC Raiders High Score Guide:How to Farm Bastions Efficiently in Spaceport ¶
Από: Florencehg στις 17/06/2026 10:59 πμ.
Have you ever had this feeling? You're fully prepared with the right ARC Raiders Items and jump into the Spaceport Harvester Event, ready to push for a high score, only to find that Bastions either don't spawn or fail to respond for long periods of time. As the minutes slowly pass, you're still stuck in place, and your score remains frustratingly low. Have you ever wondered whether this is a skill issue or simply a matter of luck? Why can some players easily break 10,000 points while you struggle just to secure consistent kills? This guide will take you from map selection to core strategies, and finally to the RNG mechanics you must understand, helping you turn a chaotic match into a controllable high-score route.
WHY SPACEPORT IS THE BEST FARMING MAP
For the Harvester Event, Spaceport is currently one of ARCR Items for sale the most consistent high-score maps.
Its biggest advantage is that the two Bastion spawn points are extremely close to each other, and there is also a Raider Hatch nearby. This makes both fast rotations and safe extraction much easier. Compared to maps like Dam Battlegrounds that require long-distance movement, Spaceport allows you to spend far more time focused on scoring.
ESSENTIAL LOADOUT FOR HIGH SCORES
Your loadout directly determines your farming efficiency.
It is recommended to bring Anvil and Hullcracker as your primary weapons, along with plenty of Hullcracker ammunition. Deadline is the core item for quickly eliminating Bastions, while Wolf Packs are useful for emergency situations in the final phase.
In addition, Zip Lines, Snap Hook, and a Raider Hatch Key are all essential. The Hatch Key is especially important-it not only guarantees safe extraction but also prevents high-score runs from being wasted due to failed escapes.
THE FASTEST BASTION KILLING STRATEGY
As soon as the match begins, head immediately to a Bastion spawn point.
When you locate a Bastion, prioritize clearing nearby enemies to ensure a safe fighting area. Then use the Hullcracker to attack its leg joints. Once the joints are destroyed, the Bastion will become immobilized.
At this point, immediately climb onto the Bastion and install a Deadline charge. Once successfully placed, the kill can be completed quickly, significantly reducing the time required per encounter. Stay calm throughout the process, and if the installation fails, retreat and try again.
THE BIGGEST ENEMY IS RNG
Many players believe the biggest threat comes from other raiders, but in reality, the true factor affecting your score is the random spawn system.
Sometimes both Bastions spawn normally, while other times they remain inactive for extended periods. Even with optimal routes and perfect gear, you cannot fully eliminate RNG. Therefore, high-score players need not only strong execution but also patience.
HOW TO MAXIMIZE YOUR SCORE
The key to high scores is eliminating the first two Bastions as quickly as possible.
The faster you complete the initial kills, the higher the chance of additional spawns later in the match. After each kill, avoid spending too much time looting; instead, move to areas like the Control Tower and wait for the next wave.
If a Bastion appears near the end of the match, use Wolf Packs to finish it quickly, then immediately extract through a Raider Hatch to secure your score.
SUMMARY
This guide is ideal for players aiming for leaderboard rankings, high-score records, or improved efficiency in the Harvester Event. By leveraging Spaceport's advantages, mastering Bastion kill mechanics, and understanding spawn RNG, you can significantly increase your chances of achieving a personal best.
TIPS
At the start of the match, always check whether both Bastion spawn points are active. If spawns seem abnormal, it may be better to reset early. In high-score runs, time efficiency is everything, since every spawn cycle can determine your final result.
CORE BENEFITS FOR DIFFERENT PLAYER TYPES
New Players:Quickly understand core Harvester mechanics and Bastion combat flow.
Score Farmers:Learn efficient routes and improve per-run scoring.
Solo Players:Reduce risk and improve survival and extraction success.
Leaderboard Players:Maximize Bastion kills and push for higher rankings and records.
SUMMARY
TIPS
