Checking review scores before buying an ARPG expansion is pretty normal, but with Vessel of Hatred, the more useful question is whether the game actually feels better once you're back in the loop. After a few sessions, that answer looks like yes. The current critic response is solid rather than over-the-top, and that's honestly fine. What matters more is that moment when you open your stash, sort your build, and realise the systems aren't fighting you as much as before. If you're already thinking about gear routes and browsing a diablo 4 item shop before the proper endgame grind begins, you're probably the exact kind of player this expansion speaks to. Why the reception feels steadier
The biggest win is that progression doesn't drag in the same old way. You notice it fast. Loot feels more relevant, build choices make more sense, and there's less of that awkward stretch where you're playing for hours without seeing anything that changes your character in a meaningful way. Critics have picked up on that, and players will too once they get past the early honeymoon phase. It's not that every issue has vanished. Diablo 4 still has that push and pull between style, pacing, and repetition. But the expansion does a better job of giving you reasons to stay on your character instead of logging off after a couple of underwhelming runs.
The usual gap between critics and players
This is where ARPG conversations always split. Some people care most about story beats, atmosphere, and whether the campaign lands. Others just want to know if the post-campaign grind is worth their weekend. That gap explains a lot of the mixed user chatter. A critic might score the expansion on structure and presentation, while regular players are judging it on loot flow, boss farming, and whether a build starts to click at the right time. Neither side is wrong. They're just talking about different things. If you're the sort of player who lives for rerolling, testing synergies, and shaving minutes off dungeon clears, your opinion of Vessel of Hatred will probably depend far more on itemisation than on the cutscenes.
Why gear still decides everything
You can feel the improvement in systems, sure, but gear is still the thing that makes or breaks the experience. That's just Diablo. A strong drop changes the pace of the game immediately. A weak setup makes every elite pack feel annoying instead of exciting. Most players don't have endless time to brute-force bad RNG, so efficient gearing matters. The smart approach is simple: finish key progression steps first, move into content with reliable returns, and don't waste too long on low-value farming. Target what your build actually needs. That could mean survivability, a damage spike, or one item that unlocks the whole setup. People often overfarm random activities when a focused route works much better.
How to get more out of the expansion If you want this expansion to click, play with intention. Pick a build with a clear path, learn which activities pay off, and stop treating every drop like it deserves a second look. The fun really starts when your character has momentum. That's why some players use eznpc for items or currency support, especially when they'd rather spend their limited time testing proper endgame content instead of getting stuck in another long streak of bad luck. Once your gear starts matching your build, Vessel of Hatred becomes a lot easier to appreciate, and a lot harder to put down.
