Legion never really stopped paying, but Mirage made the gap between a bad setup and a smart one feel huge. That's why so many players think the mechanic is mediocre while others are quietly stacking profit with almost no downtime. If you're checking the Path of Exile 1 marketplace and comparing current scarab costs to what emblems, splinters, and incubators are selling for, the picture changes fast. The mechanic itself isn't new. The economy around it is. Right now, that matters more than people want to admit. Map choice actually decides your income This is where loads of players throw value away without noticing. Legion wants space. Simple as that. The monolith has a fixed area, so when you trigger it in a cramped map, you're not getting full access to the army. Open maps feel better because they are better. You can hit more frozen targets, reveal more reward symbols, and keep your pace up instead of getting snagged on terrain. Once you run a few open layouts back to back, you'll notice the difference straight away. It's not subtle. A tighter map might still be playable, but it won't compete if your goal is steady currency per hour. Atlas passives need to support the drops, not just the mechanic A common mistake is taking every obvious Legion node and stopping there. That gets you into the content, sure, but it doesn't always squeeze the most out of it. In Mirage, the better approach is to build around what Legion drops and what actually sells. Higher-value incubators matter. Extra splinters matter. Frozen rares matter even more than some players think, because that's where a lot of the hidden payoff shows up over a long session. You don't need a fancy theorycrafted tree that looks clever on paper. You need one that feeds repeatable rewards. If a node adds more encounters but doesn't improve what those encounters give you, it's not automatically the best pick. Scarabs and speed are the real engine The scarab setup is fairly settled for a reason. First, add the extra monolith. Second, increase the number of frozen monsters. Third, lean into emblem potential for the bigger spikes. That's the core loop, and it works because every layer pushes the same outcome: more targets, more loot, more chances at a strong map. But none of it carries a slow build. That's the part some guides gloss over. In Legion, speed isn't just comfort. It's money. You've got to move fast, tag wide, then explode the screen the second everything wakes up. If your movement feels clunky or your clear radius is awkward, you'll feel it in your returns almost immediately. Why the setup cost is worth respecting There is an upfront wall, no point pretending otherwise. Good scarabs, a proper map pool, and a build that can keep the rhythm going all cost something. That's usually the bit that stalls people out before the strategy even starts paying. If you're trying to skip the slow ramp and get straight into a workable farming loop, plenty of players use U4GM for currency or item support so they can finish their build, buy scarabs in bulk, and start running the content while margins still look strong. Once the setup is in place, Legion feels less like an old mechanic and more like one of the cleanest profit farms in Mirage.
