MV AGUSTA F3 675
MV AGUSTA F3 675
  Από: pinto στις 01/11/2010 10:21 μμ.
Ειναι γεγονος! η μικρη αδερφη της agustas ηρθε για να μαζεψει κοσμο!!!
http://www.mototriti.gr/data/news/previ ... /82974.asp
den leo tipota!
Re: AGUSTAF3 675
  Από: NikosV στις 01/11/2010 10:37 μμ.
This is the 140bhp, 675cc, three-cylinder, €11,500 MV Agusta F3 that CEO Giovanni Castiglioni says will be, “the smallest supersport ever produced.” We unveiled the F3 last night and told you all about it, now we have 67 gorgeous high-res images for your perusal. This is every image that currently exists.
In addition to being lithe and almost impossibly good looking, the F3 brings two technological firsts to the supersport class: traction control, of which the benefits are obvious; and a counter-rotating crankshaft, which should cancel the majority of the engine’s vibrations. At 137bhp it’s already the second most powerful engine in the 600-ish class, behind the Ducati 848 Evo, but the 140bhp goal is almost ridiculous and would put this 675cc motor on par power wise with not only the 848, but also the 750cc inline-four of the original MV Agusta F4. If all that’s not enough, MV is also claiming that this motor is the most compact, short and narrow supersport engine too.
Make sure you check out last night’s MV Agusta F3 unveil for all the details and our interview with Giovanni Castiglioni for more information on production plans and his projected dollar price.
Once you’re done here, head on over to our EICMA tag page where you’ll find other new motorcycles debuting at the Milan show this week like the 2011 KTM RC8 R and Ducati Diavel.
photo:
http://hellforleathermagazine.com/2010/ ... /?gal=1#/0
Re: AGUSTAF3 675
  Από: NikosV στις 01/11/2010 10:40 μμ.
http://issuu.com/hellforleather/docs/mv_agusta_f3_press_information_eng/3
Re: AGUSTAF3 675
  Από: denthnpalevw στις 01/11/2010 11:06 μμ.
Ισως ειναι το επομενο μηχανακι μου....
Re: AGUSTAF3 675
  Από: dimchrist στις 01/11/2010 11:44 μμ.
Πανέμορφο είναι το άτιμο!
Το άσχημο είναι που μας πετυχαίνει σε οικονομικές στενότητες.
Re: AGUSTAF3 675
  Από: georgevts στις 02/11/2010 10:57 πμ.
Νομίζω οτι είναι αντικειμενικά πανέμορφο και όπως όλα τα MV τρομερή προσοχή στη λεπτομέρεια.
Re: AGUSTAF3 675
  Από: pinto στις 02/11/2010 9:13 μμ.
απο τι ακουσα θα παραγεται σε δυο μοντελα....την απλη εκδοση στα 9000ευρα με 9500 και την σπορτ με 11000 με 11500ευρα
εαν ειναι ετσι θα κανει τρελη ζημια σε daytona και 848evo!!!
τωρα απο την αξιοπιστια ενας θεος ξερει μονο!!!
να φανταστειτε ενας φιλος ειχε την μεγαλη αδερφη mv και η μπιελες βγηκαν απο κατω...
τωρα κλεει 24000ευρα....... ασε που δεν μπορει να το πουληση ουτε στα 6000ευρα και απο εγγυηση μεχρι (χθες) τον μπουλο
den leo tipota!
Re: AGUSTAF3 675
  Από: denthnpalevw στις 02/11/2010 9:26 μμ.
ποιος ειναι ο αντιπροσωπος εδω στο Ελλαντα???
Re: AGUSTAF3 675
  Από: nfot στις 02/11/2010 10:42 μμ.
Κατι εχει παρει το αυτι μου οτι ειναι η Ηarley Davidson Ελλαδας. Της εμεινε απο πριν, που η MV ανηκε στην HD.
Re: AGUSTAF3 675
  Από: denthnpalevw στις 02/11/2010 10:46 μμ.
Thx Νικο...
το βρηκα και στο νετ.
αυτη ειναι....
Re: AGUSTAF3 675
  Από: pinto στις 03/11/2010 8:25 πμ.
http://www.youtube.com/watch?v=sbOcAt686iw
παρουσιασει απο το σαλονι του μιλανο EICMA
den leo tipota!
MV AGUSTA F3 675
  Από: dimchrist στις 07/03/2012 3:39 μμ.
Re: MV AGUSTA F3 675
  Από: Polymhxanos στις 07/03/2012 6:39 μμ.
Είναι πανέμορφο, είναι ακόμα πιο υπερτετράγωνο από το daytona, και έχει και σχήμα εξαφανιζόλ, που εγώ πολύ τα γουστάρω αυτά.
Ειδική η προβολή του όταν το βλέπεις από μπροστά... Λες και δεν έχει μοτέρ ανάμεσα στα πλαστικά..
Και επιτέλους βγάλαν τις εξατμίσεις από την ουρά και λέπτυνε-ομόρφυνε το σχέδιο.
Στο τεύχος 500 του μοτό, έχει εξαιρετική παρουσίαση. Πάρτε το, εγώ που δεν διαβάζω πια περιοδικά, αυτό το προτείνω.
