Still struggling to break low scores while farming supply crates in the Buried City (Bird City) in ARC Raiders? Why are other players consistently hitting 11K+, while you always fall just short? Is it your route, pacing, or how you judge supply signals? This guide breaks everything down-from map selection and core gear to the double/triple drop mechanics-so you can maximize efficiency, boost your ARC Raiders Items acquisition, and push every run closer to the high-score ceiling.
Why Do Top Players All Rush Bird City?
After extensive testing, Buried City clearly has a stronger RNG profile. It offers more supply stations and better chances for double and triple drops compared to other maps. Even on good runs in Daytime Assault, most players cap around 8K, while Bird City consistently enables much higher scoring potential. If you can choose your map, don't hesitate-lock in Bird City. It's the foundation of any 11K+ run.
The Essential Three-Piece Loadout
If your loadout is wrong from the start, everything after becomes inefficient:
Grappling Hook (mandatory)-Many crates land on rooftops like the hospital. Without it, you simply lose access. Always bring one, and ideally a zipline as backup to reduce downtime.
Zipline (2-3 units)-Even with a grappling hook, ziplines make traversal smoother, especially for awkward crate locations or multi-layer buildings.
Optical Camo-Bird City is filled with flying ARC units. Camo helps you stay hidden, avoid unnecessary fights, and maintain uninterrupted signal activation flow.
Everything else is optional-nice to have, but not essential for high-efficiency runs.
Core Strategy: Signal First, Loot Later (More Runs per Hour)
Most players waste time looting early, limiting themselves to 2-3 runs per hour. The correct approach is simple: ignore loot at the start and rush supply signals.
Activate every station first, memorize whether it is single, double, or triple, and only then go back for crates. This alone can push you to 6+ runs per hour, sometimes even higher when movement is optimized and routes are clean.
More runs = more RNG opportunities = higher total score potential over time. Consistency here matters more than any single lucky drop.
For players looking to streamline preparation and progression, some also choose to buy ARC Raiders BluePrints through legitimate channels to focus entirely on high-efficiency scoring runs, reducing downtime between attempts and keeping momentum stable.
How to Identify Double and Triple Drops
This is the most important mechanic in the entire strategy:
After pressing interact (E) on a supply station:
Gray ring appears: at least double drop
Very dark gray/overlapping ring: triple drop
Once activated, spam E immediately to secure all drops.
Keep a running count:
Double = 2 crates
Triple = 3 crates
Top recorded runs have reached 11 crates, which is widely considered the current ceiling for 11K+ runs in the community.
Five Key Rules to Avoid Losing Efficiency
Don't reset just because you see only 6 stations-low quantity can still mean high-value RNG.
Always look up when activating signals to track drop direction.
Use clear compass directions (N/E/S/W), not "left/right."
Be cautious of other players using signals as bait traps.
If a crate can't be found quickly, abandon it and move on.
Who This Guide Is For & What You Gain
New players: Understand Bird City's core loop and avoid inefficient early mistakes.
High-score grinders: Learn how to consistently hit 11K+ using signal optimization and drop mechanics.
Casual players: Maximize rewards in fewer runs with higher efficiency.
Optimization-focused players: Improve loadout decisions and reduce wasted time per run.
Final Tips
Scan the map immediately on landing before moving to avoid route confusion.
Bring extra ammo for ARC encounters so fights don't interrupt your flow.
Don't chase perfection-RNG swings are normal. The key is maintaining speed and consistency across multiple runs, not overcommitting to a single attempt.
Dominate the battlefield with premium ARC Raiders Items from MMOexp.com. Whether you're hunting rare resources or preparing for high-risk raids, our fast delivery helps you stay ready for any challenge. Here is an exclusive, high-value promo code just for players:"Winter". Enjoy a 5% discount.
