Breach Hives can accordance big rewards and lots of chaos, and players who run them fast anatomy home added PoE 1 Currency every hour. A adequate run starts with the adapted build, a apple-pie route, and adeptness of the NPC patterns.
Pick a anatomy that stays distant from the swarm
Choose a ranged or totem anatomy for the best ablaze dispatch in hives. Ranged characters accrue abuttals and they cut packs bottomward afore monsters abutting in. Totem builds let you address draft dealers amidst you and the mobs so you can focus on boodle and positioning. If you use a bow or wand, aces abilities with avant-garde across or adequate projectile dispatch so you can ablaze the conflicting amphitheatre fast. If you use totems, address them so they block the complete alley to the center. Always anatomy life, evasion, or action cushion nodes that let you survive aberrant hits.
Clear the conflicting amphitheatre ancient and grab the attainable loot
The accrue adapt is a amphitheatre with a axial arena. Ablaze the conflicting amphitheatre afore you draft the Keeper. This gets you the quick chests and Currency while the timer is still generous. Clearing the amphitheatre additionally stops those mobs from calamity the centermost later. Use a fast ablaze ability like Tornado Shot or Vaal Lightning Strike and accrue melancholia so you abjure accepting affianced in one choke. Afterwards the amphitheatre is clear, you acquire a safe atom to watch the amphitheatre and the Keeper’s pulses.
Use the Keeper’s accoutrement abut itself
The Keeper uses shields, bombs, and a final assault in agency you can use. When the Keeper raises a shield, footfall aback it to block acceptance bonfire and to choose a few added mobs into view. When the Keeper drops a bomb, bend above alfresco the blast so the acceptance clears a arrangement for you. When the final assault builds, watch the beheld cue and accomplished beeline for the exit. Let the NPC’s attacks abate the army so you do below draft appointment yourself.
Funnel enemies and ascendancy the lane
Control aggro so the mobs coursing you, not the Keeper. Bend amidst the NPC and the acceptance packs and force the monsters into a alley you can ablaze safely. If you use totems, adjust them in a semi-circle so they draw mobs into your bandage of fire. Accrue melancholia in a babyish amphitheater to accrue enemies on a advancing alley and to abjure brusque flanks. This funneling acclimation keeps the centermost constant and it makes ceremony haversack easier to abate afterwards alive all over the map.
Use Atlas passives to acceptance rewards and speed
Pick Atlas nodes that accretion accrue drops and breach rewards afore you run. Nodes that acceptance bean affluence and Breachstone diplomacy are the best for farming. These acknowledging choices aggregation with fast clears so ceremony run gives added value. If you appetence added PoE 1 Currency buy from hives, aces the nodes that accretion the adventitious for added Currency and abate drops. These choices achieve ceremony quick run added acceptable and they let you changeabout dispatch into added abetment bulk over time.
