U4GM: How to Cut Vines in Bee Swarm Simulator ¶
Από: 1fuhd στις 10/01/2026 10:10 πμ.
Cutting vines in Bee Swarm Simulator is one of those mechanics that looks simple at first but ends up playing a big role in how fast your hive grows, especially in the early and mid game. Those green vine walls aren't just there to slow you down. They usually block off small parkour routes, hidden rooms, or NPC areas in fields like Mushroom and Clover, and clearing them often leads to rewards that feel well worth the effort. Once you know how vine cutting works, it stops being an annoyance and starts feeling like a shortcut to better progress Bee Swarm Simulator Items.
The first thing you need is the Scissors, which are sold in the Noob Shop near the spawn area for only 300 honey tokens. They're easy to miss, but once you buy them and equip them from the tools tab in your inventory, you'll finally be able to interact with vine clusters. These basic scissors are enough to open paths to places like the entrance to Commando Chick's hideout near the Mountain Top Field, unlocking quests and content that new players otherwise can't reach.
As you move further into the game, better tools make a noticeable difference. Clippers, which you can buy from the Ticket Tent for 25 tickets, cut through vines much faster than the basic scissors and feel far less tedious when you're dealing with thicker patches. Later on, Pruning Shears from Black Bear's shop are even more efficient and are especially useful if you plan to revisit vine spots often during boosts or events. Faster cutting means less time standing still and more time actually collecting pollen and leveling your bees.
You'll usually find vines in mid-level areas, with Mushroom Field being one of the most common spots. A large vine wall there hides a parkour section that leads to solid rewards, making it a popular early target. Clover Field and the path leading to Commando Chick's hideout are also frequent locations, and they're often tied to quests from NPCs like Black Bear or limited-time events. When you reach a vine, just make sure your cutting tool is equipped and hold the interact button until it clears. If you ever see question mark icons on the map, it's a good idea to check them out, as they often point to vine-blocked secrets.
Vine cutting becomes even more rewarding when you line it up with boosts and events. Using a Field Dice or activating a Field Booster in a field like Mushroom can massively increase pollen gains while you're accessing the hidden area. During events like Beesmas or Egg Hunts, vines tend to respawn more often and can drop extra items such as tickets, magic beans, or royal jelly. Pairing these runs with bees that boost pollen collection, like Fuzzy Bee, helps you get more value without spending time in weaker fields.
The benefits of clearing vines don't stop at immediate loot. Areas like Commando Chick's hideout offer questlines that reward eggs, buffs, and special items once you complete the parkour inside. Regularly cutting vines in boosted fields can also net you useful materials like oil, stingers, and extracts, along with fruits that turn into big honey gains later on. When combined with daily quests from bears like Brown Bear or Spirit Bear, vine farming becomes a steady way to push toward major upgrades and hive milestones Bee Swarm Simulator items for sale.
Vine cutting in Bee Swarm Simulator is one of those small systems that quietly adds up to big progress. Grab the scissors early, upgrade your tools when you can, focus on fields like Mushroom and Clover during boosts, and take advantage of event windows. With a bit of planning, every vine you cut becomes another step toward a stronger hive and faster progression.
