Ενημέρωση από Triumph (αφορά τα πιστόνια)
  Από: galileos στις 28/08/2011 10:59 πμ.
Καλημέρα,
το παραθέτω όπως το βρήκα από http://www.triumphonline.net
Dear Service Manager
RE: POOR FUEL QUALITY IN GREECE. ENGINE WARRANTY CLAIMS.
With immediate effect, please ensure customers are informed of the need to use Triumph engine management tunes entitled "Minimum 91 RON" where owners are purchasing fuels advertised as below 100 RON.
Customers who only purchase 100 RON fuel may use Triumph tunes entitled " Minimum 95 RON".
Greece has a disproportionate amount of engine related warranty claims in comparison to other markets. Extensive investigation has concluded that poor quality Greek fuel is directly responsible for this.
Every precaution has been taken to ensure that each current calibration contained in software release 2011.01 (onwards) has the maximum amount of engine protection designed within it to ensure the best engine component longevity possible. It is not possible however to ensure this protection is maintained should the motorcycle be run with a lower fuel grade than we recommend. We therefore strongly recommend that either owners run their motorcycles on 100 RON fuel to ensure the best possible longevity and performance or if customers are unable or unwilling to purchase 100 RON fuel, then these bikes MUST use the "Minimum 91 RON" tunes.
It has also come to our attention that some dealer are running the incorrect calibrations for certain motorcycle conditions (for example running an after market silencer tune, in a motorcycle without an after market silencer fitted). So called ‘tune trialing’ should not be conducted under any circumstances, as this too has been proven to directly affect the long term longevity of engine components.
As a result of this extensive research, from 1st October 2011 Triumph will no longer accept any warranty claims that we deem a result of using poor quality fuels. Any submitted claims for this will be subject to a thorough parts inspection prior to any decision being made.
We trust this information is both informative and clear.
Kind regards.
Charles Smart
Head of Department, Central Warranty Team
Triumph Motorcycles Limited
Normandy Way
Hinckley
Leicestershire
LE10 3BZ
United Kingdom
Re: Ενημέρωση από Triumph (αφορά τα πιστόνια)
  Από: Cpt. Haddock στις 28/08/2011 11:11 πμ.
Ευχαριστούμε
  Από: galileos στις 28/08/2011 11:17 πμ.
Να συμπληρώσω ότι η αναφορά έχει τίτλο και ημερομηνία τα εξής:
IMPORTANT FUEL ADVICE FOR GREEK CUSTOMERS Service/Technical 29/07/2011
  Από: ad1 στις 28/08/2011 1:25 μμ.
Α πολυ ωραια! Τελος στις αντικαταστασεις πιστονιων εντος και εκτος εγγυησης...
αυτοι πως θα μπορουν να ελεγχουν αν εμεις βαζαμε βενζινη 100σταρα?
  Από: sinister στις 28/08/2011 2:26 μμ.
Κοινως παρε το αυγο κ κουρεψε το,αντε να αποδείξεις εσυ οτι εβαζες 100αρα βενζινη αν σου πουν οτι εβαζες κακης ποιοτητας βενζινη. Δεν νομιζω οτι μπορει να βγαλει καποιος ακρη.βεβαια δεν ξερω κατα ποσο μπορει μια εταιρεια να "ακυρωνει" εγγυησεις χωρις υπαιτιότητα του χρηστη. Δεν ξερω αν στεκει απο νομικης πλευρας η ανακοινωση,δλδ θα μπορουσαν να πουνε οτι οποιος βαρεσει κοφτη σε μηχανακι του χανει την εγγυηση. Οσο για το αν μπορουν να αποδειξουν την ποιοτητα της βενζινης μπορει ο εγκεφαλος να καταγραφει τυχον "πειρακια" κ να τα διαβαζουν μετα αυτοι στον εγκεφαλο κ να σου λενε τραβα απο εκει που ηρθες.
Γενικα μπλεκει το θεμα....δεν νομιζω οτι αν γινει γνωστο αυτο θα συνεχισει να κανει πωλησεις η Τ οπως υπολογιζε.
Ο χαρτης για τα 91ron ειναι αυτος που ειχε βαλει ενα παιδι κ ελεγε οτι δεν παει το μηχανακι καθολου?
Αν θα ηθελαν να κανουν κατι τετοιο πιστευω θα επρεπε να εχουν βαλει στο μηχανακι ενα λαμπακι το οποιο να ειδοποιεί για προαναφλεξη οποτε να καταλαβαινει κ ο οδηγος οτι η βενζινη ειναι για πεταμα.
  Από: black_power στις 28/08/2011 3:43 μμ.
  Από: ad1 στις 28/08/2011 5:36 μμ.
sinister"Ο χαρτης για τα 91ron ειναι αυτος που ειχε βαλει ενα παιδι κ ελεγε οτι δεν παει το μηχανακι καθολου?
Αν θα ηθελαν να κανουν κατι τετοιο πιστευω θα επρεπε να εχουν βαλει στο μηχανακι ενα λαμπακι το οποιο να ειδοποιεί για προαναφλεξη οποτε να καταλαβαινει κ ο οδηγος οτι η βενζινη ειναι για πεταμα."
Nαι αυτο ειναι. Τουλαχιστον ας βγαλουν προγραμμα για 91 ron και να μην σερνεται το μηχανακι.
  Από: guraki στις 28/08/2011 7:35 μμ.
Οι τύποι ειναι για κλάματα και μάλλον δεν θα ξαναδούν τα φράγκα μας....το είχα βάλει το 91 Ron προγραμμα και το μηχανάκι έχασε 10 άλογα στο δυναμομετρο....στο δρόμο απλά ξεχναγες την αστραπιαία επιτάχυνση και τα αρπαγματα στις χαμηλές!
  Από: Barbadinos στις 28/08/2011 7:52 μμ.
Η ελληνικη βενζινα φταιει για τα πιστονια....Αυριο βλεπουμε
  Από: guraki στις 28/08/2011 7:57 μμ.
Μην τρώτε κουτόχορτο...στα 955τα πιστόνια ειναι ίδια πλην της θέσεως ενός πειρου...εκει δεν έχει ακουστεί τίποτα ποτε...η ίδια βενζίνη δεν ειναι?απλά οι πισωγλεντηδες κάτι άλλαξαν στα πιστόνια και συναρτησει της κακής βενζίνης γίνεται αυτο...όχι όμως ότι φταίει ο τελικός καταναλωτής!
  Από: mixalakis στις 29/08/2011 2:08 πμ.
Απλά γελοίοι...
  Από: Aris. στις 29/08/2011 2:44 πμ.
Γαμω τα British Petrols , αυτα φταινε για ολα!
  Από: vagtyrp στις 29/08/2011 6:25 πμ.
δυστυχώς αν όλα αυτά ευσταθούν για άλλη μια φορά αποδεικνύεται ότι η εταιρία είναι για το π%^#$ο!!!!!!!!!!!!!
δυστυχώς δεν μένει άλλος τρόπος από τον δικαστικό πλέον.......για να γελάσει και ο πιό πικραμένος........
αν είναι δυνατόν να φταίει η βενζίνη και τα μόνα μηχανάκια που σπάνε να είναι τα αγγλικά...........
και άντε να αποδείξεις ότι βάζεις και 100άρα..........θα κρατάμε τις αποδείξεις από τα βενζινάδικα και όταν χαλάει το μπουρδέλο μας θα τις κατεθέτουμε στην αγγλία μαζί με τη φορολογική μας δήλωση........δεν Μαμιούνται λέω εγώ καλύτερα.....
απλά απαράδεκτοι......και με το δίκτυο το ανύπαρκτο που έχουμε εδώ πέρα άντε βγάλε άκρη.........
δεν θέλω να ξαναακούσω για triumph......με την πρώτη ευκαιρία το έχω διώξει το τιγράκι όσο όσο και πάω να πάρω κανα κινέζικο......ακόμα και αυτό καλύτερο θα είναι.......
  Από: sinister στις 29/08/2011 8:21 πμ.
δεν καταλαβαινουν οτι αμεσως εριξαν την εμπορικη αξια της μηχανης,ειναι δυνατον καποιος που ξερει την ανακοινωση να αγορασει μεταχειρισμενο μηχανακι κ ποσο μαλλον tiger? Στα καταστηματα τα νεα tiger 1050 με τι χαρτη θα τα πουλανε απο τη στιγμη που ξερουν για την ποιοτητα βενζινης,μηπως θα πρεπει να αλλαξουν σε ολα χαρτες κ να ανακοινωσουν οτι το μηχανακι βγαζει πλεον 90 αλογα ή δεν ξερω κ εγω ποσα.
Δλδ σε λιγο θα πουν οτι οποιος δεν βαζει avgas δεν θα εχει εγγυηση.
Θελω να δω αν θα κυκλοφορήσει η ανακοινωση επισημα κ στον περιοδικο τυπο δια στοματος αντιπροσωπείας.
  Από: vagtyrp στις 29/08/2011 3:49 μμ.
sinister"δεν καταλαβαινουν οτι αμεσως εριξαν την εμπορικη αξια της μηχανης,ειναι δυνατον καποιος που ξερει την ανακοινωση να αγορασει μεταχειρισμενο μηχανακι κ ποσο μαλλον tiger? Στα καταστηματα τα νεα tiger 1050 με τι χαρτη θα τα πουλανε απο τη στιγμη που ξερουν για την ποιοτητα βενζινης,μηπως θα πρεπει να αλλαξουν σε ολα χαρτες κ να ανακοινωσουν οτι το μηχανακι βγαζει πλεον 90 αλογα ή δεν ξερω κ εγω ποσα.
Θελω να δω αν θα κυκλοφορήσει η ανακοινωση επισημα κ στον περιοδικο τυπο δια στοματος αντιπροσωπείας."
πάνο γιαυτό είναι και τα εξωδικάκια.......σιγά μην το βγάλουν στη φόρα, επίσημα και σε περιοδικά....την επόμενη μέρα βαράνε διάλυση στην ελλάδα και όχι μόνο.........
εγώ θα ξαναεπικοινωνήσω με αγγλία και θα τους ζητήσω εξηγήσεις και επιπλέον θα ζητήσω να το ανακοινώσουν επίσημα....
να δούμε αν θα ξαναπουλήσουν μηχανάκι....κανα ρετρό κα πού τους είναι.............
