το παρακατω ειναι paste απο ξενο forum.
UPDATE 7/18/09. Thanks to all who provided inputs and keep 'em coming including any updates/corrections to the existing list.
**DISCLAIMER: Nothing's perfect, use these suggestions at your own risk.
1. Oil Filter: BMW, 2007 CBR600RR, CBR1000RR
Comments: Direct fit.
2. Fuel Pump: Yamaha R1 (2004+), Triumph Sprint 1050.
Comments: R1 fuel warning indicator is in a different place but it's fine for a track bike. Sprint 1050 pump connections identical to D675, but slightly different internal to the tank - fixing plate needs another notch filing in it to orientate the pump in the tank correctly and fuel sensor does not work.
3. Brake Lever: Suzuki GSX-R (2003+ GSX-R750, 2004+ GSX-R600, 2005+ GSX-R1000, 2008 GSX1300BK B-King)
4. Front Sprocket: Suzuki GSX-R 600 (01-07), Suzuki GSX-R 1000 (01-07), Suzuki GSXR 750 (00-07), Yamaha R6 (99-01), Yamaha R5/RD 350, ZX-10
5. Throttle Tube: Yamaha R1, Triumph Speed Triple, Triumph Sprint 1050
6. Fuel Tank: Triumph Speed Triple
7. Front Brake Pads: Yamaha R6 (2006+), Triumph Speed Triple (07-08), ZX-9R F1-2
Comments: Direct fit. ZX-9R F1-2 kawi part number 43082-1290 (has 3 grooves instead of 5).
8. Rear Brake Caliper: Yamaha R1, 03-05 Yamaha R6, 06-up Yamaha R6S
9. Mirrors: Ducati, Suzuki GSX-R, Triumph 955
Comments: Some mods needed. See threads below.
http://www.triumph675.net/forum/show...ducati+mirrors
http://www.triumph675.net/forum/show...highlight=gsxr
http://www.triumph675.net/forum/show...hlight=mirrors
10. Clutch Perch & Lever: Yamaha R6 (2001)
Comments: Possibly other model years fit as well. Fine on race bike, may or may not be issue for street.
11. Steering Head Bearings: Yamaha R6 (99-01)
Comments: Probably compatible with other bikes as well.
12. Forks: Honda CBR 600RR (08), Kawasaki ZX6RR (03)(απο αλλο forum και του 04-06 κανουν με λιγες μετατροπες)
Comments: Honda 600RR is direct fit (may have to use RR axle). On Kawi forks, need to swap out the caliper blocks at the bottom of the forks. Caliper block is different to accommodate smaller axle - but fork tubes, caps and internals are the same.
13. Head Stock: Suzuki GSX-R1000 (05-06)
14. Headers: Triumph Speed Triple
15. Rear Swingarm Bobbins: Yamaha R6
Comments: Direct fit. 6mm bolts.
16. Footpegs: Honda CBR1000RR (04-08), Yamaha R1 (03)
Comments: Direct fit. Other model year Yamaha R1 may fit as well.
17. Front Brake Calipers: Triumph Speed Triple (07-08), Suzuki GSX-R1000, 750, and 600
Comments: Speed triple is direct fit. Suzuki calipers line up fine, but need to drill bolt holes out a little and add spacers to distance radially.
18. Wheels: Yamaha R6 (03-07)
Comments: Mods required.
http://www.triumph675.net/forum/show...+wheel+options
19. Front Brake Master Cylinder Reservoir Assembly: Yamaha R1
Comments: A near perfect fit. R1 assembly is probably less expensive as well.
20. Clutch Lever: Triumph Speed Triple (04-07), Speed Four (05-06), Daytona 600/650 (04-05), 955i (04-06), Sprint ST/RS (04-07), Thruxton (04-07), Bonneville T100 (06-07), Tiger (07), Rocket III (04-07)
Comments: Direct fit. These are based on comparing Pazzo Lever part numbers, so there may be some variation for OEM or OEM direct replacements.
21. Rear Shock Mounts: Yamaha R6 (99-02)
Comments: Direct fit. Aluminum and about an 1/8 inch lower than OEM 675.
22. Fork Seals: 05 R6
23. Wheel Bearings and Seals: Suzuki, Honda
