Xαμηλωμα σε tiger 1050
  Από: takis1964 στις 15/10/2008 11:52 μμ.
Διαβασα στο tiger1050.com τα παρακατω και τα θεωρησα ενδιαφεροντα
ειναι οι πλακες στην κατω πλευρα του ψαλιδιου που προφανως εχουν σε αλλο σημειο την εδραση του αμορτσερ με αποτελεσμα να κονταινει το tiger
μετα φυσικα θελει και το πιρουνι χαμηλωμα
Ο spinter εχει καποια παρατηρηση επι του θεματος?
Σιγουρα θα αλλαξει η γεωμετρια της μηχανης αλλα και ο αναβατης μετα θα παταει κανονικα,αφου χαμηλωνει τουλαχιστον 18mm
Του εστειλα mail για τιμη για Αθηνα
Are you struggling to touch the ground ) If so these rear suspension lowering plates are for you, and around 50% cheaper than other manufacturers prices ------ £38.00 including post & packing G.B------ $86.00 including airmail & packing to USA. ( I DO STANDARD & LOWERING PLATES, NOW MANUFACTURED IN STAINLESS STEEL ) If interested contact me at mick416818@yahoo.co.uk
Cheers Mick.
ΑΠΟΨΕΙΣ
I installed a set some time back & it's a very simple process...just jack up the rear wheel to clear the ground, remove the bolts & exchange the plates. There's a bump stop spacer that goes inside the spring. The effect seems to help handling a little, I suppose because the center of gravity is lowered. The front forks are raised 18mm or so to adjust the rake angle. If you have a short inseam, I think it's quite a safety improvement.
Ι use Mick's and have zero issues. I dropped the triple clamps about 18mm as well. Handles like a dream, and I ride fairly quickly.
Hi, i have fitted plates supplied by Mick, and confidence in riding has gone up million %, lowered front forks as well, handling just as good before lowered, but now can put both feet on the ground, well worth it and have recommended my dealer to contact mick as they were impressed enough to pass onto other customers
Re: Xαμηλωμα σε tiger 1050
  Από: takis1964 στις 16/10/2008 9:19 πμ.
Hi Takis
Thanks for the enquiry Takis, the cost to Athens inc post & packing is 51euro, you can pay by paypal or electronic transfer, all I need is your name address & post code
Cheers
Mick.
  Από: JOSBI στις 16/10/2008 9:28 πμ.
ΔΕΣ ΚΑΙ ΑΥΤΟ viewtopic.php?f=16&t=522&p=5011#p5011
VALE FOR EVER
  Από: takis1964 στις 16/10/2008 9:48 πμ.
JOSBI"ΔΕΣ ΚΑΙ ΑΥΤΟ viewtopic.php?f=16&t=522&p=5011#p5011"
το βρηκα στο site
http://www.hyperpro.com/products/height ... ringID=130
kai
https://www.bike-design.com/basket.php
με τα λιγα αγγλικα που ξερω νομιζω εχει 2 μερη
1 που χαμηλωνει ως 2cm και ακομα ενα που το κανει ως 4cm
το θεμα ειναι με το σταντ τι γινεται στα 4
το τιγκερ θα ειναι ορθιο μετα?
  Από: JOSBI στις 16/10/2008 9:57 πμ.
akis1964"
το βρηκα στο site
kai
το τιγκερ θα ειναι ορθιο μετα?"
ΕΙΝΑΙ ΚΑΙ ΑΥΤΟ!! ΜΠΟΡΟΥΜΕ ΝΑ ΡΩΤΗΣΟΥΜΕ ΤΟ ΠΑΛΙΚΑΡΙ ΠΟΥ ΤΟ ΠΟΥΛΑΕΙ!
VALE FOR EVER
  Από: takis1964 στις 16/10/2008 10:55 πμ.
ενδιαφερεσαι και εσυ?
  Από: JOSBI στις 16/10/2008 11:02 πμ.
akis1964"ενδιαφερεσαι και εσυ?"
ΒΑΣΙΚΑ ΤΟ ΣΚΕΥΤΟΜΟΥ ΚΑΘΑΡΑ ΓΙΑ ΘΕΜΑ ΓΕΩΜΕΤΡΙΑΣ ΟΧΙ ΟΤΙ ΔΕΝ ΤΟ ΦΤΑΝΩ! ΔΟΞΑ ΤΟ ΘΕΟ 1.84 ΕΙΜΑΙ!!
VALE FOR EVER
  Από: nikolasgo στις 25/10/2008 5:16 μμ.
ΠΡΑΓΜΑΤΙ ΜΕ ΤΗΝ ΓΕΩΜΕΤΡΙΑ ΕΙΝΑΙ ΤΟ ΘΕΜΑ, ΕΚΕΙΝΟΣ ΓΡΑΦΕΙ ΣΤΡΙΒΕΙ ΤΕΛΕΙΑ ΤΡΕΧΕΙ "ΣΧΕΤΙΚΑ ΚΑΛΑ"
JOSBI"
ΒΑΣΙΚΑ ΤΟ ΣΚΕΥΤΟΜΟΥ ΚΑΘΑΡΑ ΓΙΑ ΘΕΜΑ ΓΕΩΜΕΤΡΙΑΣ ΟΧΙ ΟΤΙ ΔΕΝ ΤΟ ΦΤΑΝΩ! ΔΟΞΑ ΤΟ ΘΕΟ 1.84 ΕΙΜΑΙ!!"
Ψυχιατρικη προσεγγιση...
  Από: chocoperfeto στις 08/11/2008 7 πμ.
mages to skeftome kai ego ayto to xamhloma kairo tora ama einai kai parageilete tha me syberilavete mesa kai emena?? nikos 6937290783 parte me thl ama to apofasisete.thanks
